I’m trying to add my domain to cpanel. the problem is that I can’t change the NS-record of my main domain (zubins-solutions.com) I can change it for sub domains, so I wanted to add (www.zubins-solutions.com), but then cpanel tells me not to include www in my entry. So I retry it without but then it says it isn’t on the name server because the main domain isn’t on there.
So I’ve temporarily solved it by using web.zubins-solutions.com. Which I can add. but I think that www. just looks a lot cleaner so I would like to use that instead. Is there a workaround to make that work?
I’m sorry, but there is no workaround as far as I know. To be able to use the www subdomain you will need to add the root domain, which requires you to change the nameservers of your domain.
If I may ask, why can’t you change the nameservers for your domain?
I can manually add www as a subdomain and redirect the main domain to it, which would fix the issue. but I can’t include www in my entry so I need to use something else instead.
Do you know an affordable domain provider where I can switch to? @Admin
If you want to move your domain names, we provide domain registration services at https://www.xvhost.com/ . You can get domains there at a low flat rate.
