Any Human Exits here ? please help me its very important.
please help me this enquiry
https://webcache.googleusercontent.com/search?q=cache:DAZ89nFDXmEJ:interstellarinnovs.info/+&cd=1&hl=en&ct=clnk&gl=in
No any idea what the hell do you want, where’s the error, why you providing google cached website, what’s wrong with your empty website.
I can’t tell if your website even using InfinityFree nameservers.
please read this tread. i had explained all issues sir. nobody responding
now my site is showing this error " HTTP ERROR 508"
try : http://interstellarinnovs.info/wp-login.php
Admin asnwered you enough. I can add only that you should delete database as well if you’re re-installing WP to avoid conflicts.
admin hasn’t even understood the issue & its not enough. by deleting database i will loose all my data & site stats, do you know about this ?
Yes, but installing second WP over first isn’t good idea if the SQL looks like “CREATE TABLE IF NOT EXISTS” or smth like that, do you know what will happen?
I said the error looks like confict, whatsoever you always can google this problem and find tons of solutions.
It’s not hosting issues, but software one.
You are getting 508 Error maybe because you consumed your allowed resources try refreshing may solves the problem.
site interstellarinnovs.info is loading for me but if you have edited or uploaded your own template of WP than it’s incomplete and doesn’t contain some files.
