Hi guys,
In order to run my app, I need to change the Apache server and PHP settings. How do I do that on the infinityFree, please?
Below are my required settings:
Apache server settings
->Enable rewrite module
->Give read-write access (755) for the below listed folders
a. application-root-folder/protected/runtime
b. application-root-folder/assets
c. application-root-folder/protected/config -
PHP settings
->Enable pdo_mysql extension
->Enable curl extension
->Set max_execution_time = 3000 ms in php.ini
->Set post_max_size = 8 MB in php.ini
->Set upload_max_filesize = 20 MB in php.ini
