Hi there. I got a problem with my hosting. When I upload any engine on ftp server after 10-20 sec its auto deleting .htaccess , index.php , favicon and robots.txt. Tried to create a dir and put it in other dir , but didnt helped. Could smbd help me ?
Hi
is it the same if you use some ftp program from the control panel ?
please leave here your acc name (epiz_xyxyxy) for admin to check around 19-20h CET
Please check whether you uploaded your files to the htdocs folder, files uploaded outside a htdocs directory are deleted automatically.
I was convinced that users canβt create dir outside of htdocs (now i know that only files outside of htdocs are deleted but not directories)
@OxyDac said:
Hi
is it the same if you use some ftp program from the control panel ?please leave here your acc name (epiz_xyxyxy) for admin to check around 19-20h CET
epiz_21711320
I dont have htdocs directory , it that wrong ?
just create htdocs dir and put your files inside
Now ,Im getting HTTP ERROR 500 when I try to enter on my site.
also check your .htaccess file
or please wait admin to check your acc
Warning: require(./system/global.dat): failed to open stream: No such file or directory in /home/vol3_3/epizy.com/epiz_21711320/htdocs/index.php on line 2
Fatal error: require(): Failed opening required β./system/global.datβ (include_path=β.:/usr/share/pear/β) in /home/vol3_3/epizy.com/epiz_21711320/htdocs/index.php on line 2
get more files deleted , lol
@OxyDac said:
https://infinityfree.net/support/http-error-500/also check your .htaccess file
Now all its working , OxyDac thx for help <3
yw
congratulations and good luck !
