I installed Autoptimize plugin on my website, and since then, I have seen a decline in the number of clicks using Google Adsense. Does Autoptimize affect Adsense scripts? What should I do in such a case?
Well. I don’t know it myself because i never did it. There’s not much coding helpers. We mostly answer hosting issues. You should ask it on sites like stackoverflow.com mostly which you can get more and better answers
I agree. I am running https://hamarigossip.com but I dont find any issue with this plugin. Maybe I didnt noticed. Did u get the reply.
Yes I did. One of them said it wouldn’t mess up if I did not happen to minify the JS code for Adsense. Makes sense.
