inffre
#1
Hello,
I can’t connect with filezilla for FTP to the server. Other FTP client work.
Here is the log :
Response: |
220-This is a private system - No anonymous login |
Response: |
220 You will be disconnected after 60 seconds of inactivity. |
Command: |
AUTH TLS |
Response: |
502 AUTH TLS OK. |
Command: |
AUTH SSL |
Error: |
Could not connect to server |
All connected information are properly entered. I have tried several times. I can’t find the issue.
Thanks for your help.
Can you try replacing the hostname to ftp.epizy.com and then try?
inffre
#3
Hello,
Thank you.
I have tried but it gives the same error.
thanks
Maybe the server is congested. Waiting for a few hours and trying again may help.
inffre
#6
This is happening for at least one month. So this is not a congestion problem.
Furthermore, this is only a FILEZILLA problem because this is working on other FTP software.
thanks
Than maybe try uninstalling and re-installing FileZilla. Or just use this “Other FTP Software”
system
Closed
#8
