Where is the most cheap custom domain provider? And where is the extension?
123-Reg-Co or Namesilo (recommended by IF)
I think .xyz & .site are the cheapest now. Black Friday btw
Ok so the most cheap domain provider is?
If you want a free domain, Freenom.com is the place for you.
But if you want a cheap, reputable domain, go to NameSilo.com. They have hundreds of extensions and they are fairly inexpensive.
um hostinger or namesilo is my go.
Ok so I will use namesilo
I bought a domain with them one time, hated it. 200INR for DOMAIN PRIVACY PROTECTION? Literally every domain registrar gives it for free. exception for the money hungry GoDaddy ofc. and lets talk about the support, literally every support staff gives different problem bruh. NEVER USE HOSTINGER unless you have no PayPal. Only reason they’re good is cuz they support UPI
Um well I have 5 domains with them over many TLD’s. I have never faced any issue.
I have 2 .coms 1 .xyz and 1 .org with them. There’s not a option to register nameservers without pointing it to their own servers, support is unreliable, and they’re just money hungry. 200RS for Domain Privacy protection. It’s 2021 almost 2022.
If you’re using CF create NS records pointing to your reseller IP.
Some providers wont work like that. They need the nameservers registered.
I’m not a reseller. I manage my own DirectAdmin server.
