https://matematikk.ml
CLOUDFLARE ERROR : Sorry there was a problem activating cloudflare for this domain or the email address ********@ .com, this is normally caused by the email address or domain name already existing on the cloudflare system.
idk why bc i deleted my account and domain from the cloudflare network ._.
If you are activating Cloudflare using InfinityFree’s VPanel, don’t do it that way.
Disable Cloudflare in the VPanel and do this instead:
DO NOT USE THE CPANEL INTERGRATION
This is the proper way (the cpanel thing is broken)
Change your name servers to cloudflare
Set up cloudflare through the dashboard
Add these cname records at cloudflare:
Content: your main domain
Content: @
Make sure to click the orange cloud until it goes gray
Pros
Bypass cookie / javascript checks
Full DNS management
I hope this helped
I forgot this, but ANY DNS records need to be added through Cloudflare, not vPanel (tha…
i was just reading that. the integration worked fine everytime except for now. Thanks BTW
The cloudflare DOES work through vpanel, but it’s very glitchy
system
Closed
May 21, 2021, 5:58pm
#5
