hi,
i have a problem,
my domain registrar is cloudflare
cloudflare don’t have an option for modify nameservers
what can i do?
thanks
hi,
i have a problem,
what can i do?
thanks
Then you cannot host on free hosting
Hello
Unfortunately, you can’t host your domain with InfinityFree if your registrar is Cloudflare. I would recommend that you move the domain away from Cloudflare as soon as you can, generally 60 days after registration.
i think maybe with artificial inteligence become posible
No, AI is not going to change how our backend systems work
ok,
i try the hostinq with the free subdomain
Hi,
Since Cloudflare do not allow changing Nameservers for your apex domain, you have the following solutions:
The second method only works if you are not having a CMS/login system in place
