Hi, I followed all the steps in detail of this guide, but my domain armonia.uk goes to suspendeddomain.org/n/. My registrar is cloudflare.com and I have pointed my domain to my InfinityFree.net IP address
. Can you please help me?
Unfortunately, you won’t be able to host your domain with us if your domain is registered with Cloudflare, since cloudflare does not allow you to change your domains nameserver.
I have another domain, angelitos.com, which is also from Cloudflare and works perfectly using the same steps, can you check this please?
That is not the way to use free hosting.
Domain must be pointing to ns1.epizy.com and ns2.epizy.com in order to be added to hosting account.
This domain works because it was successfully added to a hosting account.
And that most likely happened before domain was transferred to CloudFlare
