Hey Where can i get cname record values of infinityfree . net
My Domain is taken from names.co.uk
For ssl certificate i want to set up cname on infinityfree . net
You can set up CNAME records for your domain in the control panel under the “CNAME” section.
The CNAME records you need to add for SSL certificates are shown to you in the SSL certificates tool. They are unique for the domain (for Let’s Encrypt) or the certificate (for GoGetSSL), so there isn’t a standard value to use.
