Since yesterday 12:00 PM my cron jobs no longer runs. (runs very well since 2 months)
Itās configured to run each 2 minutes (hours empty)
Iāve tested it directly itās works pefect in just miliseconds. So iāve deleted the cron job and create a new one with same parameters but never runs
Hello
Tks @wackyblackie for your help. Iāve read this post
In my case everything is ok :
cron job url is ok
cron job each 2 minutes
cron job hour empty
cron job execute very quickly (less than a second)
Until yesterday everything was perfect, iāve change nothing
The exact same thing is happening to me. My last successful CRON ran at 20/03/2022 11:15:00 GMT. I was also running it every 2 minutes. It has been working fine for 3 months. There are no errors or warnings anywhere I can see. The cron was not āautomatically deletedā for taking more than 5 seconds, cos it was still there. Iāve deleted it and set it up again, nothing. Unfortunately āinfinity freeā block outside CRONs from other servers accessing their servers. Iāve even tried using CURL to bypass this but it is also blocked.
Huh. My guess is that the downtime yesterday may have affected this. Hopefully more information will be available soon. @DaveTheDuck, can you please provide your EPIZ_ username?
I may have spoken too soon. Stopped working again after 22/03/2022 10:25:20. Maybe because I deleted the original one and added a new one, so maybe itās the new one thatās not working.
@DaveTheDuck my cron is working.
In my case I have deleted the original and create a new one maybe 10 times.
I have only one cron job in all my cron job list.
Itās configured to run each 2 min but in fact runs each 2,3 or 4 min.
Itās working again at 22/03/2022 14:31:35. I delete the CRON again which was for every 2 minutes and recreated it for every 5 minutes. I think this is when it started working again. I will experiment later but it seems the only time it has worked today is when the CRON was for 5 minutes and 2 minute CRONs have not worked at all today.
