Is there anything wrong with Infinity Servers?
Websites seem to be down.
Everything seems to be working fine from here. @keri45 's site is working fine as well, @rockstar-me didn’t give me any site to check.
same here, site down, then up again, then down again.
tested via Phone and cable.
The infinityfree.io domain is not supported for client subdomains. Due to a technical error, it was temporarily visible in the subdomains list, but those domains do not work.
The servers are working fine, but you need to make sure you’re using an epizy.com, rf.gd or one of the other subdomains in the Subdomains list.
