I create a calendar in my system. The data that will display in full calendar i get from database. I want to ask why the data did not display in hosting but in my localhost it display
Did you try to debug the code? Can you verify the database query was executed successfully and returned the right data? I’d be happy to try to help you with this, but I need a bit more information than “works on my machine” to do so.
thank you for your response. This problem is solved. It my mistake. Thank you again.
