Database Issues
Screenshot should explain what the problem is abc.bmp (3.0 MB)
What could be the problem?
More precisely, how can I solve it? I am sure that the problem with connecting to the database
Try this first to display the actual problem:
and:
ΠΌΠΎΠΆΠ΅Ρ‚ Π±Ρ‹Ρ‚ΡŒ ΠΌΠ½Π΅ Π½ΡƒΠΆΠ½ΠΎ ΠΈΠ·ΠΌΠ΅Π½ΠΈΡ‚ΡŒ sql210.epizy.com Π½Π° Π΄Ρ€ΡƒΠ³ΠΎΠΉ, Ρƒ мСня Π±Ρ‹Π»Π° ΠΏΡ€ΠΎΠ±Π»Π΅ΠΌΠ° с Π΄ΠΎΠΌΠ΅Π½ΠΎΠΌ ΠΈΠ·-Π·Π° этой ΠΏΡ€ΠΈΡ‡ΠΈΠ½Ρ‹?
Π³ΠΎΠ²ΠΎΡ€ΠΈΡ‚Π΅ Π½Π° английском, поТалуйста :slight_smile:
maybe I need to change sql210.epizy.com to another, I had a problem with the domain because of this reason
To see your database information. Login to your site vpanel from client area. Then go to MySQL Databases, There’re your DB Information!
