How to add DDoS Protection?
Hello
If you have a custom domain name (not a free subdomain) you can utilize Cloudflare for their CDN and DDoS/bot protection.
Hello,
I will show you how to easily set up Cloudflare, Edit Records, and Troubleshoot with images!
PLEASE READ BEFORE STARTING!!!
Cloudflare cannot be used on free subdomains from InfinityFree
You can use Cloudflare on Custom Domains (yoursite.com ) and with Custom Sub-Domains (subdomain.yoursite.com )
A video tutorial can be found at the end of this guide, should you get stuck.
You must connect your domain to your InfinityFree account first. Read more here .
------- Set-Up Cloudflare -----…
Hey want to talk you I have paid domain in hostinger when I connect infinityfree host through name server than I can’t connect waf when I connect waf than I can’t connect infinityfree host how I do? I want your email or insta etc for get help
Well, you have opened multiple topics.
Still pending your reply…
I’m sorry, but I’m going to need a LOT more information to help you.
With WAF, I assume you mean a Web Application Firewall? Such a WAF involves running security checks against web requests on the server to block any harmful requests before they can do damage.
We don’t have WAF as an explicit feature, but we do have a system to protect against bots, as well as various custom rules to block some known bad traffic.
You are by no means required to use a WAF, and using a WAF does not typicall…
Please read the guide I linked above, it explains how you can use Cloudflare with InfinityFree.
system
Closed
June 11, 2023, 5:24pm
6
