i set up infinityfree SSL .now i want SSL remove
Hello
You cannot remove SSL certificates from the client area. To remove the certificate from your website, open the SSL/TLS section of the control panel and delete the contents of all three boxes.
Certificate box delete . but Private Key box cannot delete because Private Key box cannot blank
You are good then. Both keys need to be there for SSL to work.
