I’m still a little confused, here is a screenshot of what I have.
Move the .htaccess
file to ../
, that is the folder that is ahead of the public/
folder, and move also the rest of the files of the public/
folder on ../
, delete the public/
folder after moving those, and open the .htaccess
file with a text editor to remove the comment, that is known as #
on lines 9 to 14. After that, edit index.php
and flarum
to include the folder of your vendor/autoload.php
file, that is surely on the same folder as index.php
, and also the storage and public folders should be on the same folders as index.php
So I have moved the contents of the public
folder, and deleted it
I have opened up index.php
. Now what do I do?
Remove the /..
on lines 16 to 18 and the ../
on line 12 on the index.php file, and do the same for the flarum
file.
Ah, I forgot to say: remove '/public'
on both files, index.php
and flarum
So it should just be ''
Instead of /public
It should be only __DIR__
, not __DIR__.''
or other things.
For the other one, AKA storage, it should be __DIR__.'/storage'
Ok, what do I do now?
Do I upload it to my hdocs
now?
Did you uncomment lines 9 to 14 on your .htaccess
before doing that? If not, do it.
Yes, I did
Should I upload it to my hdocs now?
You should upload all files on your subdomain’s htdocs
, that is for example forum.yourdomain/htdocs
, with a FTP client.
Thanks very much for your help! I’ll let you know if anything doesn’t go to plan!
Unfortunately, this didn’t seem to work. I open up my website, and it says:
This page isn’t working
forum.ifhub.rf.gd is currently unable to handle this request.
HTTP ERROR 500
enable display errors from alter php config on cpanel.
it says this:
Parse error : syntax error, unexpected ‘,’ in /home/vol12_1/epizy.com/epiz_24698714/forum.ifhub.rf.gd/htdocs/Flarum/index.php on line 16
on line 16 change __DIR__
to __DIR__.'',
