Thanks, it works now.
Ah, one last thing, I am setting up flarum, what is the table prefix?
And where can I find it
it comes first of each table on database, for example on bayo_users
,bayo
is prefix
I now get this error when I press install:
Something went wrong: SQLSTATE[42000]: Syntax error or access violation: 1286 Unknown storage engine ‘InnoDB’ (SQL: create table ifhubforummigrations
(migration
varchar(255) not null, extension
varchar(255) null) default character set utf8mb4 collate ‘utf8mb4_unicode_ci’ engine = InnoDB)
I typed that into mySQL, and got the following error:
#1273 - Unknown collation: ‘‘utf8mb4_unicode_ci’’
Use this code instead:
create table ifhubforummigrations (migration varchar(255) not null, extension varchar(255) null) default character set utf8mb4 collate 'utf8mb4_unicode_ci';
I still get this error when pressing install:
(migration
Does infinityfree have InnoDB? Could that be the problem?
Ah. Could there be a workaround?
