Blank white screen both on the homepage and wordpress/Joomla admin pages.
On browser it redirects me to vardagstod.se/?z showing a blank white screen.
If I delete my domain and add again, it helps, but overnight the same thing happens again.
I’m using this software:
Joomla, but the problem is the same with Wordpress.
Additional information:
I use SSL from PositiveSSL, but overnight it changes back to Cloudflare’s SSL, though I already disabled Cloudflare.
I use unique MX records for Zoho Mail.
Now it happened again.
It worked for you, because I deleted and re-added my domain, but it has crashed again. If you see the site now, it won’t work.
I did NOT make any changes since my first post.
Sorry, I wasn’t too clear.
I meant that the site currently is down.
When I made the first post, THEN it worked, because I re-added my domain, but I can’t do it in every two hours, that’s why I need a permanent solution.
