I used Cmd+Shift+C as I tried on Chrome on Mac to open the inspector, BTW, and it opened the same. I also suggest to put other security defenses for that combination of keys, so that it won’t even open using those keys.
Jquery isn’t defined, Ahaha
stop looking at my code cuz I’m noob coder html
shhh, we’re hackers, we don’t like to ignore codes >v<
outside joking, html is a public code. you cannot alter anything with inspect element permanently.
Developers play with I-E to debug stuff.
Php is a ghost, that wont be visible in I-E
I just realized that my friend thinking and my thinking was wrong about php lmao
probably
Remember, you and your friend, PHP and JavaScript don’t match!
gotta try tommorow add the domain name ok. it’s probably down…
For example I’m javascript and @Ergastolator1 is Php, we’re different. different coded (?), different behaviors and etc.
but we help people together.
just need to remove this stupid <sript attribute
wait is there anyway to add php code to html?
Script is useful. i can make lot of magic using that
<?php
echo 'hello!';
in body tag. with php extension.
No, you can’t add PHP codes on HTML files. You must use a .php
file for that.
dats a bruh moment
also, is the freenom only service to give free domains?
Php is backend , that cannot make pages with live effects unlike JS, but that can also connect to database and alter it
, Unlike JS.
it also gives .com
, .net
etc domains but for money.
but f r e e domains services not only freenom?
or its only pay?
only pay for those domains. free for ga
, ml
and some other two letter domains.
I cannot buy an only-pay domain RIP
still can’t register a domain name…
Contact freenom staff?
