This is what i get when i try to open database.
I quess i lost that website, im totally lost, so i think it is time to start again.
Shame
just a tips. When You want to start again, donât have ssl yet and want to install ssl, consider to make self-signed ssl before add other ssl. So, You will have 2 ssl. For example self-signed ssl and zero ssl. It will make easy doing something.
I took a look at your account. A few things that caught my attention:
- You changed the password outside of the client area. Do not use the password reset functionality of the control panel itself. Doing so doesnât update the password in the client area, which means the password displayed there will be incorrect, and many client area features, such the one-click login buttons, wonât work anymore. Also, the client area may occasionally sync its own password to the hosting system, which may break your site. There is never a need to use the reset functionality, you can view and change your hosting accountâs password at any time through the client area.
- The configuration file of your WordPress site references the database
epiz_33436771_w705
. This database doesnât exist anymore. Creating a new database wonât fix this. If you deleted the database by accident, and you donât have a backup, your only option is to restart from scratch.
At this point, I would recommend to deactivate the current account, create a new account with your custom domain, and install WordPress on it with Softaculous.
