Been getting these for a few weeks, assumed the limits had changed and it was time to start looking elsewhere . I know this sounds bad but I am happier that itâs a problem at your end and we have a chance of this been fixed and it isnât something I have done
Can you check my account and let us know the situation. I do use .php but it is not a busy site.
I have also noticed during the same time that pages with multiple images may take a few refreshes before all images appear.
This is likely the reason why youâre getting suspended.
About a month ago, rate limits were put in effect as well, which limits the number of files that can be loaded at a time. If you have a page with a lot of assets (usually images), youâll hit that limit and additional requests will fail. If your site hits that limit a lot, it will be suspended.
So I think everything is working as intended for your account. You may want to optimize your page to reduce the number of concurrent requests, for example by implementing lazy loading for the images, or just displaying fewer of them per page.
I split your posts to a separate topic. Discussing why your account specifically is getting suspended is not a subject for an outage topic.
No. They were, and still are, a closely guarded secret. A few people at iFastNet know the exact values.
Could you share links to some of the specific pages where sometimes not all the images load? I checked a few pages on your site, but I didnât see any with a large number of images, or images that did not load.
The key issue is the number of requests. Making your images smaller doesnât help here.
Yes, thatâs how rate limits work. You can fire a certain number of requests, and any requests after that get blocked. So, say, the first 20 images load, then the limit is hit, and all the images being loaded in after that get blocked.
Perhaps the limits are incorrect. But then weâd see a lot more people whose account got suspended for hitting the EP limits, and looking at the statistics, the exact opposite is happening.
And if an issue affects a small number of sites, my assumption is that it has something to do with what happens on those websites.
I have tested with different browsers and desktop / mobile and get the same result.
I am still convinced that the problem is still connected with the âEP Limitâ problem you stated in the original post.
Although I didnât note the dates the problems started, the date you stated (21st April ? ) definitely seems about right,
This is around the time that both the âimages not loadingâ problem and the âEP Limitsâ emails started.
Nothing changed to the website, no noticeable increase in traffic.
I had never had the âreached 50%â email prior but then suddenly I am receiving them and the suspensions (last was this week Mondays / Tuesday).
@Old-Rotherham hi, i was also having issues with my gallery which has around 180 images and the ep limit suspensions
i removed my domain name from my old problematic account
created a new account with the domain name assigned to it
uploaded my website
cloudflare ddos protection enabled and a page rule to cache everything
Thanks, I will give that a try, probably over the weekend.
I currently have the IF domain name and a paid for domain name that I just forward to it.
Are you saying I can remove the IF domain from the account, create a new account and assign the same domain name? This will mean that the paid domain name will then be forwarding to the new account?
Iâve talked to iFastNet about this and they have made some changes which should help with this.
Aggressively caching everything with Cloudflare shouldnât be necessary. You should be able to host a website here with some images on a page without getting suspended.
Been looking in to the settings as it looks like your suggestions are going to be the ones to go withâŚ
So currently have the free InfinityFree domain. ( www.old-rotherham.rf.gd/ )
Also have a paid for domain which is currently just forwarding to the Free domain. Will leave this for the moment until the rest is sorted then follow your advice to use âParked Domainsâ.
I assume when I add a new account it will not allow me to add the same .rf.gd domain. Is it possible to get www.old-rotherham.rf.gd on to the new account?
or would it be a case of creating a new domain (maybe use one of the other extensions)? Would it then be possible to park the original .rf.gd domain to catch any links that are floating about on Facebook etc
Yes.
If you request a page, for example /folder/file.php on the old site, your 301 redirect will take you to the same page on the new site. It will even redirect GET parameters (but NOT POST parameters).
