epiz_27293346
http://yourtune.rf.gd/
403 Forbidden
The website’s configuration prevents you from accessing this page.
Hello everyone, i am getting this error on forms.
For example my register form and update user info forms give me that error, but my login form works.
I am using PHP & MySQL
the register and updateuser files are in the same folder as the login one, and they have the same permissions.
Thanks.
Do you try signing up? That’s his problem
i already cleaned the chache, the problem only happens when i fill up the register form and press the button to register
check the /includes/user_register.php file for errors.
also check the permissions for the file
I already checked permissions and errors. And the website works well in my localhost
do you use mysql databases?
then check those for errors as well
Well, i think, if i don’t have any erros in my localhost server, it shouldn’t be giving any error, and the connection to MySQL database is correct, because i can login and other stuff, i just can’t register and update user profile.
system
Closed
January 27, 2021, 9:51am
#12
