my website is https://shoppingsolution.ml but when i click on the product from menu it redirects me to 404 error page. why??
because it’s probably a template and is not a full-featured website
It is up to you to create non-existent pages
Also meta name = "keywords"
is enormous
and should be separated by a comma
It’s best to keep meta descriptions long enough that they’re sufficiently descriptive, so recommend descriptions is between 50-300 characters (google will ignore the rest)
From what I can tell, your website software wants to do some URL rewriting. Usually, this requires a file called .htaccess
to be present.
I have checked your account and I see there is a file called htaccess.txt
. Could you try renaming that to .htaccess
and see if it fixes the URL.
