ERROR 414 - URL Too Long!
Username: epiz_27443383 Website URL: emtech12humss11.rf.gd
Is there any available fix to this? Please help. This is due tomorrow. =(
Aside from not having any technical knowledge, because our course does not really involve this kind of things (but apparently we had to take this subject).
I would be actively monitoring this topic, and would respond incase more information is needed.
If you are using WordPress, Wordpress is causing the infinite redirect loop.
Easiest way will be to reinstall WordPress
Is it possible to do that without losing the actual website that we made? And also, how do I reinstall it?
First, backup your website.
1)Goto Softaculous
2)Installation
3)Click Backup icon
4)Backup
Done, what’s next?
Make sure backup is created
Download the backup
Done, I have checked. There’s a backup for our website.
Goto Database
Click Admin
Export the following tables (postmeta, post, termmeta, terms, term-relationships and term_taxonomy)
Make sure checkbox are correct
Uncheck display comment
Click Go to export tables
Hi, it told me new users can’t attach new documents.
So I uploaded it via Google Drive.
Link: https://drive.google.com/file/d/1AY8SlNurHskI4j9feZpVyqxCCybbXA8u/view?usp=sharing
So I assume you have successfully created backup of your website and sql tables.
Remember where you saved your files.
We now proceed to remove current WordPress and then reinstall.
Goto Softaculous
Goto Installation
Click on X to remove current installation
Click to reinstall WordPress
Hi, I have re-installed Wordpress, what to do now?
First you extract the backup of your website onto your pc/laptop
Upload the backup of your uploads directory into /htdocs/wp-content
Done.
What’s next for this one, I have extracted the files onto my laptop.
Open the sql file containing postmeta, post, termmeta, terms, term-relationships and term_taxonomy using textpad++ or notepad++.
Replace the previous prefix with current prefix
To play safe, show me screen shot of edited sql file
Hi, where can I find that .sql file?
Remember where you save this file?
Once edited, pls save as another name
Like that?
The main domain is ed9vlysw.epizzy.com
Then the actual link is emtech12humss11.rf.gd
And also by the way, what will I name it?
I think you got it wrong.
Pls show me your current wordpress database.
It shd look like below.
This is what my current WordPress database looks like, by the way its still me but for some reason I have limit on posting.
This is an urgent matter so I’ll drop my email: amirkhalil.sioson.shs@ust.edu.ph incase I can’t respond anymore.
