This either means that the username and password information in your wp-config.php file is incorrect or that contact with the database server at sql310.byetcluster.com could not be established. This could mean your host’s database server is down.
Are you sure you have the correct username and password?
Are you sure you have typed the correct hostname?
Are you sure the database server is running?
If you are unsure what these terms mean you should probably contact your host. If you still need help you can always visit the WordPress Support Forums.
I never Faced this specific problem before I knew you have daily limit on the website …
So I started facing this problem only Today after you re-enabled my website
I tried some solutions on many Topics on this forum but it didn’t help , If It is not from your side tell me So I can Remake an account… but you really should check the pictures , I have to keep updating the web page more than once till I access it , and I use CloudFlare but I don’t think It’s the problem
Your website is probably using all of the php scripts allowed of free hosting, sometimes it will display a message telling you this & other times it will just give you database errors.
Yes , I fixed The problem , I use all the PHP rss when I load the website , I purged Cache on Cloudflare and removed few Plugins That was using a big amount of PHP rss .
Thanks for your answer.
