I seem to be having a database error. I checked my website this morning to see that it showing that. Wasn’t showing that error yesterday since I left it.
https://
This either means that the username and password information in your wp-config.php
file is incorrect or we can’t contact the database server at sql111.byetcluster.com
. This could mean your host’s database server is down.
- Are you sure you have the correct username and password?
- Are you sure you have typed the correct hostname?
- Are you sure the database server is running?
If you’re unsure what these terms mean you should probably contact your host. If you still need help you can always visit the WordPress Support Forums.
