[### Username (e.g. epiz_XXX) or Website URL]
epiz_32307260
(http://fundicionblanco.infinityfreeapp.com/ )
Plugin JoinChat for WordPress doesn’t work
GET https://errors.infinityfree.net/403/ net::ERR_ABORTED 403 admin.php:2166
Line 2166:
I tried to use the JoinChat plugin for my WP website, but it doesn’t run properly as it seems like the code is being blocked. If there is a way to configure it to use it, I hope you can support me.
Hello!
Unfortunately, live chat scripts are banned and cannot be used on InfinityFree.
For more info:
While working on your website, you may be redirected to the InfinityFree 403 error page . This article explains why this can happen, and what you can do to solve it.
The directory does not contain an index file
If you try to request a URL without a file name in the URL (e.g. http://example.com/ or http://example.com/blog/), the server will look for a so-called index file.
An index file is a file with the name index.php, index.html, index.htm or index2.html in the folder you’re trying to access.…
system
Closed
August 16, 2022, 12:06am
3
