Username epiz_26766532 WebSite: https://www.goldenage.rf.gd/
Error Message: ERR_SSL_PROTOCOL_ERROR
I have not installed any certificate so that this appears to me, is there a solution?
Yes, The solution is to install a certificate!
Very funny -_-
Sorry? Im being serious, the only way to remove protocol error is to install a certificate.
Also use a custom domain to use ssl bruh
SSL can be installed on either free subdomains or domains, you just cant use the ssl tool for free subdomains.
Wait, i think it’s impossible.
It’s possible,the ssl tool in IF doesn’t provide cert for free subdomains.
But there are some other companies which can give ssl for free
Let’s Encrypt have support to infinityfree?
