Check client area to see account is suspended
Hello. Sory, but where is account suspendition reason? I can not find it on Infinityfree account page
I see redirects button, but there are not any redirects
There is no suspension.
Did you setup the domain correctly?
Please show the CloudFlare dns entry
I used this guide to setup my domain, but i did not add records with my account IP adress, because it was information that Cloudflare adds them. I will check DNS settings of domain. Thanks
After opening your account in a browser window with the Network tab open, I see your https://kotyaken.xyz/ redirects to https://kotyaken.cf, which doesnβt seem to be active anymore.
If youβre using WordPress, this is likely caused by an incorrect Website URL. Fortunately, you can change that without having access to wp-admin directly in the database:
Thank you for answering. I used kotyaken.cf domain before i bought kotyaken.xyz domain
