I’ve read the list on how to set this up but im still receiving this error.
db.php
<?php
// Enter your Host, username, password, database below.
$con = mysqli_connect("sql{NUMBER}.byetcluster.com","USERNAME","PASSWORD","USERNAME_register");
// Check connection
if (mysqli_connect_errno())
echo "Failed to connect to MySQL: " . mysqli_connect_error();
um some information are wrong i guess
look try to write this code
<?php
// copy the code and fill these vars
$servername = "sql204.epizy.com";
$username = "your login username";
$password = "your login password";
$dbname = "you database name u wanna connect with";
try {
$conn = new PDO("mysql:host=$servername;dbname=$dbname", $username, $password);
// set the PDO error mode to exception
$conn->setAttribute(PDO::ATTR_ERRMODE, PDO::ERRMODE_EXCEPTION);
echo "Yeah it's working";
catch(PDOException $e)
echo "Failed To Connect " . $e->getMessage();
Similar problem problem
_ = Hidden
failed To Connect SQLSTATE[] [] Access denied for user ‘epiz_NUMBERS’@‘192.168..__’ (using password: YES)
<?php
$servername = "sql300.epizy.com"; $username = "epiz_NUMBERS"; $password = "PASSWORD"; $dbname = "epiz_NUMBERS_register";
try { $conn = new PDO("mysql:host=$servername;dbname=$dbname", $username, $password);
$conn->setAttribute(PDO::ATTR_ERRMODE, PDO::ERRMODE_EXCEPTION); echo "Yeah it's working"; }
catch(PDOException $e) { echo "Failed To Connect " . $e->getMessage(); }
Oxy
#4
and please use code formatting tool
Admin
#5
I can check this issue for you. What is the name of the database you’re trying to connect to?
I have just fixed it, (I guess I had the wrong password/or it changed) thanks non the less.
system
Closed
#7
