Hie guys,
Please help, I have uploaded my fully functioning website hours ago. It was online and loading correctly just minutes ago, I happen to see that it is now loading without CSS, images and icons.
I am supposed to have this up today. I kindly I need some help.
You can press F12 then goto console to see the reason why they’re not loading, Would you try to visit www.squavero.com/ ? if that works clear your browser data or use another browser.
Then it’s maybe a problem with your DNS cache. Please purge it, or if it still doesn’t work configure a faster DNS resolver like 1.1.1.1 or OpenDNS on your device.
On your Network Settings of your computer, depending on which OS you’re using. On Windows it could be changed by right clicking on the network icon and clicking “Open Network & Sharing Center”, then clicking on “Edit card options”, right clicking on the network card you’re using and clicking on “Properties”, then selecting “Internet Protocol Version 4 (IPv4)” and ticking “Use the following DNS server names:” before putting in, in case of 1.1.1.1, 1.1.1.1 and 1.0.0.1, and in case of OpenDNS, 208.67.222.222 and 208.67.220.220 or 208.67.220.222 and 208.67.222.220 in the fields, then clicking “OK”, and closing all the tabs.
It seems like the security system blocked some parts of your website for you. You’ll have to enable both JavaScript and cookies on your browser in order for your website to be seen correctly.
The developer console in your browser shows that it’s trying to load the files from some other IP address and port: 10.150.35.17:6510. I have no idea why it does that, because in your code I don’t see any hard references to domains or IP addresses.
