fceu_17977331 [Wordpress] Upload_Max_FileSize Exceeds
Hello!
Thank you for fast and quick support that you provide. But could i request to increase my upload max filesize limit?
I am uploading a visual composer plugin on my website, but I guess my limit was 10 mb, but the plugin is about 15 mb.
Could you help me increase my upload limit even upto 15 or 20 mb only?
Thank you! Have a great day.
I’m sorry, but in order to block file sharing sites from being hosted with us, we cannot increase the file upload limit. However, there is an alternative way to install Wordpress plugins. You can do a manual installation: Managing Plugins « WordPress Codex
Oh ok. Thanks! I am able to upload the plugin using FTP. Btw, your free hosting is great! :slight_smile: Thanks!
Hi, Bro, how do I Enable SSL in the Cloudflare, instead “turned off the feature” Yes
Cloudflare doesn’t support this feature for partner registrations, you can only use Cloudflare’s Flexible SSL when signing up directly through Cloudflare.
You can however enable SSL through your hosting control panel as well. However, you will need to get your own SSL certificate to do that.
How the min, and right there is no DNS ZONE EDITORS, how I’d like to cloudflare
Hopefully in the future there are dns editor
It sounds like just using Cloudflare to manage your DNS would be a win-win for you: you can use both Cloudflare’s DNS controls as well as all other features they offer. Check this post for more details on using Cloudflare manually: https://infinityfree.net/forum/topic/243/cloudflare/1#post-907
Yep, you cannot have your own free SSL but you can enable CloudFlares SSL (Flexible SSL). As said by InfinityFree Admin, you must configure it like I did on cloudflare’s configurations. Regards! and Thank you again for this great host!
