So apparently the filemanager is dead.
Tried to log in but failed.
Not even filezilla allows connection
It is same for me, fix this please
Try again with Filezilla. Filezilla is working.
By the way before creating new topic, you can check latest topics to avoid topics duplication.
but i need filemanager more than filezilla right now
If you want to use filemanager.ai then you have to wait until it is solved. If it’s urgent, you can go with Filezilla.
File manager and FileZilla are the same thing. Just use FileZilla until the file manager gets fixed.
Update: filemanager.ai 404 Error Solved. Now you can use filemanager.ai.
resolved
