i’m using FileZilla to connect to my free site and im getting a 530 Login authentication failure
I see there is two different Hostnames to connect and both don’t work for me or I just haven’t waited the full 72 hrs. Is there something I may be missing?
I should say I’ve tried both. Not using both at the same time just to clarify. I’ve checked my PW over 10 times… changed port to 21 and nothing… tried my 5lb hammer and all that did was stop my connection and crashed my pc. Guess I shouldn’t use that anymore.
I will check again. I do believe it was just that as I had to agree to have it change all pw related to the site. Not to mention it shows the password if you want it to in the FTP manager
Connecting to ftpuploadnet through FTP proxy
Status: Resolving address of ftp.epizy.com
Status: Initializing TLS…
Status: Verifying certificate…
Command: USER eqiz*****
Response: 331 User eqiz_**** OK. Password required
Command: PASS *************
Response: 530 Login authentication failed
Status: Waiting to retry…
Status: Connecting to ftpuploadnet through FTP proxy
Response: 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
Response: 220-You are user number 246 of 6900 allowed.
Response: 220-Local time is now 17:40. Server port: 21.
Response: 220-This is a private system - No anonymous login
Response: 220 You will be disconnected after 60 seconds of inactivity.
Command: AUTH TLS
Response: 234 AUTH TLS OK.
Command: USER eqiz_****
that’s the error code. I had to remove the “.” in ftpupload net so it would post to the site… not sure what’s going on. I’ve tried everything on that I can think of…
It has to be the fact that enough time hasn’t passed for it to be set up. I don’t see why there isn’t a “Status” for it. It’s really starting to bug me since it’s either that or I really am missing something stupid. This isn’t the first time I’ve set up FTP…
There are some common issues with FTP which can cause unexplained authentication errors. Some of the things in that article may seem random, but they do fix the issue.
Could you try that with ftp.epizy.com. Some networks have blocked the ftpupload.net domain for unknown reasons. The log you previously shared from the connection attempt to ftp.epizy.com seemed to have more success.
