mangos.epizy.com
Could not select database, error 403
So here is what I’m trying to do:
I am creating a database and post request to fill it up in order to store information from a video game / research application. I have all of my hosting set up finally and am using a script on my website here, SendData.php, and a class in my application called ServerManager.cs (C#) to handle the post request.
I am really new to this and could be making all kinds of mistakes, but it looks like I’m just having an issue with authentication in my post request. I’m gonna share the php script and the link to connect to it so you can see what I’m talking about and I’m also going to share the C# script. If you have any tips on how to improve my situation I’d really appreciate the help.
Post Request example:
http://mangos.epizy.com/SendData.php?sex=male&age=20-30&race=caucasian&sleep=7&black_correct=10&black_incorrect=5&color_correct=10&color_incorrect=5&equation_correct=10&equation_incorrect=5&hash=a35da8d967492144a869b5591f9e5c59
The above data is not sensitive
SendData.php (sensitive data has been replaced with ‘XXXXX’)
<?php
$db = mysqli_connect('sql106.epizy.com', 'epiz_XXXXX', 'XXXXX') or die('Could not connect: ' . mysql_error());
$selected = mysqli_select_db('epiz_26340998_number_research', $db) or die('Could not select database, burp, mooooorty');
// Strings must be escaped to prevent SQL injection attack.
$sex = mysqli_real_escape_string($_GET['sex'], $db);
$age = mysqli_real_escape_string($_GET['age'], $db);
$race = mysqli_real_escape_string($_GET['race'], $db);
$sleep = mysqli_real_escape_string($_GET['sleep'], $db);
$black_correct = mysqli_real_escape_string($_GET['black_correct'], $db);
$black_incorrect = mysqli_real_escape_string($_GET['black_incorrect'], $db);
$color_correct = mysqli_real_escape_string($_GET['color_correct'], $db);
$color_incorrect = mysqli_real_escape_string($_GET['color_incorrect'], $db);
$equation_correct = mysqli_real_escape_string($_GET['equation_correct'], $db);
$equation_incorrect = mysqli_real_escape_string($_GET['equation_incorrect'], $db);
$hash = $_GET['hash'];
$secretKey="handbanana"; # Change this value to match the value stored in the client javascript below
$real_hash = md5($sex . $age . $race . $sleep . $black_correct . $black_incorrect . $color_correct . $color_incorrect . $equation_correct . $equation_incorrect . $secretKey);
if($real_hash == $hash) {
// Send variables for the MySQL database class.
$query = "insert into scores values (NULL, '$sex', '$age', '$race', '$sleep', '$black_correct', '$black_incorrect', '$color_correct', '$color_incorrect', '$equation_correct', '$equation_incorrect');";
$result = mysql_query($query) or die('Query failed: ' . mysql_error());
ServerManager.cs
using System;
using UnityEngine;
using System.Collections;
public class ServerManager : MonoBehaviour
private string
secretKey = "handbanana"; // Edit this value and make sure it's the same as the one stored on the server
private string dbSendData = "http://mangos.epizy.com/SendData.php?"; //be sure to add a ? to your url
// public string dbURL = "http://localhost/Number_Mangos/display.php";
public string sex;
public string age;
public string race;
public int sleep;
public int black_correct;
public int black_incorrect;
public int color_correct;
public int color_incorrect;
public int equation_correct;
public int equation_incorrect;
// remember to use StartCoroutine when calling this function!
IEnumerator PostData()
//This connects to a server side php script that will add the name and score to a MySQL DB.
// Supply it with a string representing the players name and the players score.
string hash = Utility.Md5Sum(sex + age + race + sleep.ToString() + black_correct.ToString() +
black_incorrect.ToString() + color_correct.ToString() +
color_incorrect.ToString() + equation_correct.ToString() +
equation_incorrect.ToString() + secretKey);
Debug.Log($"Hash generated: {hash}");
Debug.Log(dbSendData);
string post_url =
$"{dbSendData}sex={WWW.EscapeURL(sex)}&age={WWW.EscapeURL(age)}&race={WWW.EscapeURL(race)}&sleep={sleep}&black_correct={black_correct}&black_incorrect={black_incorrect}&color_correct={color_correct}&color_incorrect={color_incorrect}&equation_correct={equation_correct}&equation_incorrect={equation_incorrect}&hash={hash}";
Debug.Log(post_url);
// Post the URL to the site and create a download object to get the result.
WWW hs_post = new WWW(post_url);
yield return hs_post; // Wait until the download is done
if (hs_post.error != null)
print($"There was an error posting the high score: {hs_post.error}");
public void Start()
Debug.Log("Hello world!");
StartCoroutine("PostData");
There are some things to optimize in the C# code but I’m still playing with the classes that will interact with it. I really just want to get the base case working. Any help is greatly appreciated
