I tried many times to upload my WordPress files using filezilla and most of the other FTP clients but none of them worked, all I get is error messages alot of Error messages, I tried every solution. I even tried other operating systems (Linux distros) But nothing changed.
Has anyone encountered the same problem?!!
this is not just an InfinityFree problem, I have tested almost every free hosting out there and they all have the same problem.
“Response: 421 Timeout - try typing a little faster next time
Error: Could not connect to server”
Error: GnuTLS error -110 in gnutls_record_recv: The TLS connection was non-properly terminated.
Status: Server did not properly shut down TLS connection
Error: Could not read from socket: ECONNABORTED - Connection aborted
Error: Disconnected from server”
"Error: GnuTLS error -110: The TLS connection was non-properly terminated.
Error: Transfer connection interrupted: ECONNABORTED - Connection aborted
Error: Failed to retrieve directory listing
