Hi,
my website travel-in-budget.ml is showing connection timed out. Kindly help me out with this admin.
Thanks
Hi,
Thanks
before you go to editing pages think about this:
if you do not want to have a /WP/ in the address (call WP with sub/domain)
you can just delete the old installation, go back to Softaculous and install it again with the right directory. Double and triple check the “ Directory ” field in Softaculous, it should be empty if you don’t want a subdirectory!
softaculous - if you want to uninstall
on the toolbar (up right) the box icon is located (the mouse above that icon will write “all installations”)
click it
and then https://softaculous.com/docs/How_to_remove_a_installation
