What happened here?
Analysis Error
An error occurred fetching the page: HTTPS error: certificate verify failed
"There may be a connectivity issue between your server and the GTmetrix test server. Please login to try testing from another test location or try again later.
The Certificate I use is Zero SSL. Can anyone here predict what happened and help me fix it.
The Certificate was set to expire on October 5, 2022. I inserted the private key first then upload it then inserted the certificate key and generate csr. I have completely answered all the field in there. Still was not sure on what happen, maybe some records like MX, AAA and more are missing in some areas or missing completely are causing this.
