My Username is
epiz_32296726
poppybarktvsby.site
ERR_CONNECTION_TIMED_OUT
Yesterday my website is worked, now i want to update some codes but the website is down, the cpanel is working but the site is down, can you please help me.
Thank You
KangJL
August 24, 2022, 4:54am
#3
MrPoppy:
You need to check with your domain registrar
That is not true. More likely some domain registration issue
hello thanks for your reply, im using cloud flare name server on domain, how to add 2 more name server from infinityfree to domain setting
KangJL
August 24, 2022, 5:17am
#5
Do not do that. Never mix nameservers!!!
Just add in A record will do.
Follow this guide
Hello,
I will show you how to easily set up Cloudflare, Edit Records, and Troubleshoot with images!
PLEASE READ BEFORE STARTING!!!
Cloudflare cannot be used on free subdomains from InfinityFree
You can use Cloudflare on Custom Domains (yoursite.com ) and with Custom Sub-Domains (subdomain.yoursite.com )
A video tutorial can be found at the end of this guide, should you get stuck.
You must connect your domain to your InfinityFree account first. Read more here .
------- Set-Up Cloudflare -----…
Make sure to resolve domain registration issue in the first place
i’m sorry but i already did that before
the website before is working,
KangJL
August 24, 2022, 6:05am
#7
Did you
You domain is likely onhold by your registrar pending verification
Make sure A record is pointing to 185.27.134.102
al ready pointed to 185.27.134.102, wait maybe i need re add record
is it working if i delete my domain on domain addson and re add it again?
KangJL
August 24, 2022, 6:22am
#10
Keep doing that. It’s never going to work.
Unless you
MrPoppy
August 24, 2022, 6:34am
#12
i’m sorry i didn’t get it it the first place lol,
i already resend registar verification, and already verif it sir
MrPoppy
August 24, 2022, 6:35am
#13
do i need add record in domain registar sir? or is it enough in cloud flare?
KangJL
August 24, 2022, 6:42am
#14
What nameservers are you using now?
MrPoppy
August 24, 2022, 6:43am
#15
KangJL
August 24, 2022, 6:45am
#16
Just wait for dns propagation
MrPoppy
August 24, 2022, 6:52am
#17
thankyou for your guidance sir, i dont know why this happen, the site is working before tho
MrPoppy
August 24, 2022, 7:04am
#19
im so gratefull to you sir, im sorry if i made mistake hehe
thanks for the support and guidance, wish you happy life sir!
system
Closed
August 31, 2022, 7:05am
#20
