please help, I have transfered my Database and files from my local server successfully, and I have also done the normal configuration of the wp-config.php. But each time i try to access my site what i see is Error establishing a database connection. programasgratiscomkeys.epizy.com
My username epiz_21869213
Are you sure you’re entering correct credentials?
Database user should be your username ‘epiz_21869213’
Database name should be: epiz_21869213_name
Database password should be your cPanel password.
Database host should be sql###.something.
A good first step to solve issues like this is to enable debug mode in WordPress. To do that, find the line with WP_DEBUG
in wp-config.php
and change the false
to true
After refreshing the page, you should see a lot more information about why the connection failed. You can probably find the actual error message in this article: https://infinityfree.net/support/common-mysql-errors/
Don’t forget to disable WP_DEBUG
again afterwards, it’s a security risk to have it on by default.
Hello! Thank you both for answering. I solved that the problem was that the host was wrong, the host that I had was the one I had when I made the backup.
@VPHrishikesh said:
Are you sure you’re entering correct credentials?Database user should be your username ‘epiz_21869213’
Hello! Thank you !
