Hello, again. Can anyone just tell me how I can convert jpeg/png images to webp images on my website?
Hello there,
You can use this tool to convert your images manually:
You can also use this WP plugin that specializes with converting images to WebP if you’re using WordPress of course:
Yes, I used them, but they didn’t do the conversion. The plugins show an error saying that the webp extension is not enabled by the server. Could you please check the issue?
Well I do not remember WebP being disabled on free hosting. There’s probably a WordPress settings that you need to turn on to enable the WebP extension.
You may try to use this plugin:
Thanks
