Hello!
This guide will explain how you can host a subdomain of a domain name you own with InfinityFree without hosting the main domain too. Here is the example I will use in the guide.
Note: I will be using terms that you may not recognize. Please read the first section of this article on domain names if you get confused.
You own the domain example.com and want to add the subdomain blog.example.com to InfinityFree. However, you do not want example.com to be hosted with InfinityFree. Here is how we can accomplish this!
(Optional) Send out a notice to your users saying that your website may be down for a few hours starting at X time.
Change the nameservers of your second level domain (example.com) to InfinityFree’s nameservers. And add the domain to your InfinityFree account.
Open the control panel, and select the “Subdomains” section. Enter your subdomain name (blog), then select your domain name (example.com) from the drop down.
Open the file manager or access your website via FTP and confirm that there is a folder with the name of your subdomain (blog.example.com). If there is not, attempt to create it yourself, and if that doesn’t work please open a new topic in the Hosting Support category.
Change the nameservers of your second level domain (example.com) back to what they were before.
Locate your DNS zone provider (This is the company you pointed your nameservers to, it is not InfinityFree).
Add a new A record on your DNS zone provider with the following information:
CONTENT: The name of the sub-domain (blog).
VALUE: The IP address of your account. This can be found in the client area.
Wait for DNS propagation. This process can take up to 72 hours.
Once your new subdomain starts working, congratulations! Now sit back, relax, and like this post
Have additional questions? Reply below or open a new topic in Hosting Support.
