I’m stuck at this setp
by or do they mean they only have to add one of the following?
what pirority do I set mx record too?
Follow this:
Starting at step 6 is what you want.
You can delete the MX and FTP records that Cloudflare makes for you. Only keep them if you know what to set them to (If you don’t know, you don’t need them).
it’s the same thing though
the priority should be given to you by the mail server you are using…
As I said
So since you don’t know what do do with it, delete it. You only need it if you have a mail server, in which it looks like you don’t.
