video more help, my indoes used over full and i try to find where can i delete files.
where it?
You can decrease you Inode usage by deleting files from the file manager which you will find on the control panel or your can use the FTP details found on the Control Panel or on your user area of the InfinityFree panel to access the server and delete files that way!
i want remove site i install i cant find this what i can do?
If you installed it you will need to go back to the softaculous app in the cPanel and then to current installs and then click remove the desired one.
Best Regards,
Alan T.
@AlanTiller said:
If you installed it you will need to go back to the softaculous app in the cPanel and then to current installs and then click remove the desired one.Best Regards,
Alan T.
i can video please?
