How to add SSL, to freenom domains? I have a free domain at freenom, then I added nameservers of infinityfree, then then I go to ssl in infinity account and then added my domain, it was asking to add cname records to freenom, so I did, but I had to select the freenom default nameservers to do that, means I had to turn off the epizy nameservers, after that I came back to infinity and refrsh the cname button, it gave me an error saying - The required CNAME record could not be found.
and when I set the nameservers to epizy one, I can not add the cname in freenom as they not alow for it, please help.
To add to what @Ergastolator1 said, you should really check the instructions we’ve provided first on how to add CNAME records. These are the official instructions which are verified to work. Spoilers: they don’t involve any DNS or nameserver changes at your domain registrar.
That same article has some answers to frequently asked questions. Including the question as to what to do if you just set up the CNAME records and you still get errors in the SSL panel.
