Hi! I made some requests to get my certificate, but after that I wanted to change the type of it.
So I end up with 3 validations… only I don’t know where to go to delete some of them.
Here is the panel:
I do appreciate that you took the time to translate this message for us.
As for the SSL, you cannot delete anything from the control panel, but thats ok. The only way a certificate can actually affect your site is if it is installed in the control panel. So to use the GoGetSSL certificate you have, all you have to do is install it!
Go to your Control Panel, navigate to the SSL/TLS section and click Configure next to the domain you want to set up.
Take the Private Key you already have, paste it in the Private Key field and click Upload Key.
Take the certificate text you already have, paste it in the Certificate field and click Upload Certificate.
