My website URL is: http://homeexercise.club
What I’m seeing is: I want to get the SSL certificate
I’m using this software: Wordpress
Additional information: Sir I have registered for free hosting Service and my custom domain, now I want to get free SSL service please help me.
htere is a ssl certificate from client area home. you can use that or use cloudflare works too!
Sir i am doing the same but yet facing an error of “Unable to connect to domain name”
Magnus
April 15, 2020, 9:28am
#4
Are you using Cloudflare? @krishnapathak5337
Magnus
April 15, 2020, 9:32am
#6
On your other topic you just created, you said you used InfinityFree SSL…
actually sir i was using both
but now i have disabled the cloudfare
Magnus
April 15, 2020, 9:36am
#9
Wait for Cloudflare to fully deactivate and then see if it works, otherwise, you have misconfigured the SSL / SSL certificate you uploaded.
Magnus
April 15, 2020, 9:40am
#12
That’s probably because you haven’t installed the domain in the panel. You need to go to the cPanel / Vistapanel and add the SSL certificate. Instructions are here:
In order to get a padlock in the address bar in your website, you need to install an SSL certificate on your website. This article describes how to do that. If you would rather watch a video, scroll down to the bottom of this article. Installing...
sir i have done from cpanel
Magnus
April 15, 2020, 9:48am
#14
Then wait for the changes to become active.
My website URL is: https://homeexercise.club/
What I’m seeing is: there is showing an error of “Unable to connect to domain name ”
I’m using this software: wordpress
Additional information: I am trying to installing SSL certificate for a custom domain but I am facing an error of “Unable to connect to domain name ”
Magnus
April 15, 2020, 9:26am
#16
Are you using Cloudflare SSL or the InfinityFree SSL feature?
Magnus
April 15, 2020, 9:31am
#18
If you have just installed it, make sure to wait until it becomes active and works. Make sure you did it like described in here:
ok sir i will wait for while
Magnus
April 15, 2020, 9:37am
#20
→ Please take a look at your another topic. Avoid opening two for the same problem.
