Hi Guys!
I’m Rana Khashif Sarfraz. I joined Infinityfree a week ago. I found that many peoples on Infinityfree forums talking about SSL certificate for free. Most of them don’t know how to install Let’s Encrypt on infinityfree, so, I decided to write an article on forums so just follow my steps.
Cloudflare
Sign Up for Infinityfree
Transfer your domain to Infinityfree by changing nameservers
Sign Up for Cloudflare
Transfer your domain to Cloudflare by changing nameservers
Your Site will not affected by changing nameservers
Goto Crypto and SSL security and select Flexiable
Congrats you have install SSL
But Cloudflare SSL are not for your domain it is common name issued to sets of domains and are specified to some browsers but it is easy.
Let’s Enrypt
2. Transfer your domain to Infinityfree by changing nameservers
3. Sign Up for Cloudflare
4. Transfer your domain to Cloudflare by changing nameservers
5. Wait it is the same steps chill bro wait for next steps
6. Goto www.sslforfree.com
6. a) Enter your domain
b) Select Manually Verify Domain (DNS)
c) It will give you some TXT records to
d) Copy Them
7. Goto Cloudflare and select DNS mangement
8. Paste the Records(TXT) that you copy
9. It will give you private key and certificate
10. Open cPanel select SSL/TLS
11. Select your domain
12. Upload Key First
13. Upload Certificate
14. Congrats you installed the certificate
the above mentioned are the only ways of getting SSL/TLS for free on free hosting using Infinityfree. Note: By the use of second step repeat the same steps for subdomains as for main domain Note2: By using Cloudflare add A record of subdomains pointing towards your IP and enable traffic through CloudFlare
Congrats it’s enable! Hope you enjoy!
@Ranakhas said:
Hi Guys!
Cloudflare
Let’s Enrypt
d) Copy Them
Hi, I’ve tried sslforfree.com before but it was a bad experience.
My website was flagged as Unsecure because it’s a Self-Signed certificate.
It has been a few years ago since I tested it.
I will try it again and verify is it legit or not.
@Ranakhas said:
null @PlanetGamingGG actually sslforfree.com didn’t give you the certificate themselves they give you the Let’s Encrypt signed certificate.
Got this error : ERR_CERT_AUTHORITY_INVALID Sigh Any advice?
No ssl certificates will work from websites such as sslforfree.com if you have a free account, for some reason. Try using cloudflare, it will be available on cpanel.
Cloudflare gives you:
-SSL
-JS and CSS caching (makes your website load faster)
-Development & Attack mode
-And other things
All for free! You can also buy a paid account there, to get access to even more features.
-SSL
-And other things
Hope it helps!
Yes but my site is diffrent and if I used cloudflare (tested it before) it will break it!
But now the SSL works fine.
Dear sir
I want to get certificate via let’sencrypte but I have tried by your method there’s one problem in cloud flare couldn’t copy paste that txt record from ssl.com because there’s showing message below
DNS Records
Your DNS zone file is hosted by Byethost, a Cloudflare partner. Changes to your DNS settings must be made through the Byethost website
Well,
As a matter of fact,
I successfully inserted my letsencrypt certificate, It’s legit I really inserted my cert!
The only thing that I can’t insert is my wild card ssl certificate!
BTW @Admin can we pm each other about ssl? because of something
@UnknownLolz said:
Well,
If it’s a very important message about a sensitive system issue, you can send an email to [email protected]. But know that any support questions like “can you set up my SSL” or “why do you block sslforfree.com” will be rejected.
PMs are not enabled on this forum because it was only used by people to send support requests to me.
Well,
I can’t really say it’s so important but it just about I want to talk with you about your web hosting ssl, because you are using the cloudeflare free ssl without your common name (e.g. infinityfree.net). This is just all about your current ssl now that you are using the shared ssl…
So I can’t really say that it’s so important. But if you are curios is it okay if I question you about this?
@UnknownLolz said:
Well,
Send your question over! Vaguely describing your question here won’t get it answered.
@PlanetGamingGG
It says Self-Signed cause you haven’t uploaded your CA_Bundle.
CA_Bundle is the one that verifies your ssl if it was issued by a trsuted CA.
And also the ca bundle is given to you by the certificate authority.
For Example:
You get an ssl from Comodo and the CA_Bundle is just like your csr and private key but the common name of it is the CA’s Domain and the CA_Bundle will verify your legitimate ssl certificate!
And also if you are concerned about these, I have a topic where you can just add an htaccess code to verify your ssl that it was issued from a trusted ca,
It works fine for me,
I also have encountered your problem too but I just add this htaccess code and the browser finally trust my ssl cert!
Here’s the code:
RewriteEngine On
RewriteCond %{HTTPS} off
@PlanetGamingGG
For Example:
Here’s the code:
RewriteEngine On
Please note that what @UnknownLolz wrote here is not correct.
CA bundles are not supported on free hosting but modern browsers don’t need them either. A browser either trusts a certificate or it doesn’t, and you can’t make a browser trust a bad certificate using codes on your website. What would the internet look like if a phisher could make his website look trusted by adding a few lines of code?
What likely happened in @UnknownLolz case, the certificate was installed correctly but the browser cached the old, invalid certificate. The fact that the website worked after adding the .htaccess codes was purely coincidental.
@PlanetGamingGG
For Example:
Here’s the code:
RewriteEngine On
And also I think Admin is right about my answer so I shouldn’t be sharing this code back over and over again lol
But still you can try the code yourself if you are curios
@PlanetGamingGG
For Example:
Here’s the code:
RewriteEngine On
That .htaccess code should enforce a redirect to make sure all visitors always use HTTPS on your site. That said, your code might break on particular circumstances (e.g. when using poorly configured Cloudflare or if we change some server settings on our end), which is why we recommend slightly different code: https://infinityfree.net/support/how-to-force-all-traffic-to-https/
